Paddle Shifters
After years of cars with standard transmissions, we compromised with a Honda Fit: my wife got the automatic transmission, and I got the paddle shifters. But now I’m wondering - would continual use of the paddle shifters wear the transmission prematurely?
Actually it should make the transmission last longer by avoiding unnessesary shifts.
My wifes 02 Sonata has the automatic with the slap shift/manual mode.
I find this to be very handy in stop & go freeway traffic as I can lock it in 1st or 2nd & control speed with the throttle for the most part & it keeps the transmission from shifting needlessly everytime I ease up on the throttle.
Don’t worry about it. If there was danger of transmission damage Honda would not put the paddle shifters on the car. Shift to your heart’s content.
As always, it depends. If you use any automatic transmission aggressively to over-rev on downshifts (harder to do on a stick because of the synchronizers if you don’t know how to double-clutch) or you continually play with the transmission “because you can”, then I would say it’s potentially hard on the transmission. Holding the transmission in a lower gear is regular practice for automatics in heavy traffic, but you don’t need paddle shifters to do that…move the shifter lever to a lower gear and keep it there until you need to upshift after traffic clears.
The paddle shifters are a marketing gimmick, IMHO. They provide little extra control on a transmission that has the disadvantage (or advantage depending on your perspective) of being an automatic. Changing the shift control from the lever to a button changes nothing. It’s all in how you choose to drive it.
I like not having to remove your hands from the wheel to shift. The disadvantage I see is one more electronic thing to flake out in five years.
The paddle shifters should cause no problems. The “manumatic” transmissions in some cars override the driver’s gear choice in certain situations. Personally, I would prefer a shift lever on the center console since it is always in the same position.
F1 driver’s go over 200 MPH and use paddle shifters. If they can do it at those speeds, we can certainly safely use paddles at our well-under 100 MPH speeds.
It’s a mass produced automobile with fairly new technology and no one knows what is going to happen with the transmission down the road. A lot is going to depend on how aggressively and how often those paddles are used along with maintenance habits.
A Honda nameplate does not automatically mean no problem with a transmission; or anything else. If that were the case then there would not be this.
http://www.honda-acura.net/index.php?categoryid=1&p2_articleid=24
Your transmission is a CVT manipulated by the computer. The answer would be no if you can do better job than it does in an automatic-mode. Besides, unnecessary shifts may cause wrist tendinitis which is not covered by the warranty.
Either way, it goes into a limp home mode(usually it has a 3 maybe 4 continuous steps to cease operation) if you abused the CVT too much.
False, its not a CVT but a 5 speed auto with paddle shifters added on.
Automatic trannys today are all controlled electronically by a computer. The only difference is which signal the computer is responding to. And, whether you’re using paddle shifters or just leaving it in sutomatic mode, the computer will not allow you to do anything that wil damage the engine or tranny.
just shift, pretend you’re in a Bugatti Veyron, and enjoy.
True, the 7 speed CVT is not currently available in the US.
Someone mentioned F1 paddle shifter steering wheels, they are not quite the same thing (and they cost more than most cars): (-;
But you can buy a pretty nice replica for ?2400:
http://www.lapassione.co.uk/?pid=display&cat=2&sub_cat=59
