2000 Buick Century with intermittent transmission surges while changing gears.
 A local mechanic read the computer codes and determined a P1811C code but checked Step 11 of the AllDataPro readout.
 Inspect transmission for the following:
 * 203 accumulator piston seals rolled
 * 2-3 accumulator piston and pin missing
 * oil pump assembly damaged
 * spacer plate and gaskets damaged
 … etc.
 P1811 is the Maximum Adjust and Long Shift code on Buick.  What does the “C” add?  And, does the Step 11 indicate actual internal damage?
 I have been advised that there’s a gasket easily replaced on the side of the transmission with the Maximum Adjust code, but I’m wondering if this test indicates there’s internal damage and a total repair is needed.  Thx.
