P1326 cel engine code. vehicle in limp mode. gas 2.4 GDI
Your Snap-On scanner may not be up to date. Fault P1326 was added the the PCM via a software update to detect engine bearing failure using the knock sensor.
The system is flawed, electrical interference in the wiring can cause false alarms. An overlay wiring harness has been developed to correct the false alarms.
Here is a tread with a dozen other people with the same problem;
