Code is for tcc stuck on. Code p0741 is tcc stuck off. So, it’s a sticky solenoid. Which means it may start out sticking occasionally and progress to sticking more often and finally staying on/off permanently? If u get the code/symptoms 1 time, does it usually mean it will happen again, soon?
0741 is stuck off. 0742 is stuck on. i have heard of folks who get both codes. there is a pressure sensor manifold switch assy which can fail and somehow tie into the codes.
