Here¹s the throttle body relearn procedure
- Start the engine and let it idle in park for 3 minutes. During that
period the idle may be higher idle than normal. -
- After 3 minutes, turn the engine off and leave it off for 60- seconds…
- Start the engine again and let it idle in park for 3 minutes one more
time. During these run periods you may see a check engine light. Scan for
codes and if you get throttle body related codes, clear them.
- If the idle speed is still off, drive the vehicle at speeds above
44-mph and operate several acceleration and deceleration cycles. Then repeat
step #3 one last time.
I have been driving the vehicle for a month now with no issues.
