Oil in my radiator reserve, but no water in my oil. car overheating. Whats going on???
Probably a bad head gasket.
Yup, agree, bad head gasket.
Check the transmission fluid.
If the transmission fluid cooler in the radiator has a leak, transmission fluid will get into the coolant. And coolant will get into the transmission. Causing the transmission to run hot.
