I have an oil leak and I dont have any idea where its coming from. Any ideas?
You’ll have to get a little dirty to find it unless someone else looks. We can’t see it from here.
Drops or puddle? Color?
Place a large sheet of clean cardboard (open up a large box) on the ground/floor under the engine/transmission and check where the drips drop onto the cardboard. That will give you a starting point.
its actually puddles and theyre dark. im pretty sure its coming from behind the engine.
well then you do know where it’s coming from.
ok now wat do i need to do to fix it
where exactly is it coming from?
ill have to get under there and check it out but i can only do it 2morrow so ill get back to u
