hi, i have a 1999 durango slt 5.2 and it has a major problem: the odometer is out. as most of you know the dash is mechanical and the odometer is digital. the only other lights that do not light are the 2wd/4wd light. can i fix it myself or should i prepare to spend $600. or so?
If you have a speedometer shop in your local area then you might want to give them a call to see what it would cost to repair. It may be a simple fuse/connection problem but then again it might be something more complex.
