Trying to find it
Resistance to the ground should be 0 (zero!)
Make sure to check your tester wires resistance first, as you can expect something like 0.1-0.2 ohm in wires on their own.
I don’t need to take the PCm out right?
I put a heater in the car to dry overnight
If the PCM is wet you should remove the PCM, clean and dry it. If there is water damage to the PCM connector you should clean and dry the connector.
Only you can see how deep the water is in the car, we can only imagine that there is enough water to cause damage.
Ok how water resistant are these PCMs?
how much water can they handle before they break?
and whats a quick way to test the PCM?
They’re not.
Less than your cell phone.
If I dry it will it work ?
I mean, one of the bolts is rusted and rounded…how can I remove that?
