For some years, I worked in a contract defense factory. Our equipment had to be extensively tested at very hot and very cold temps before shipping.
We had large chambers, technically called environmental chambers, though we normally called them Burn-in Chambers. They were capable of running from 100 degrees C. to -50 C. perhaps colder, but out tests were usually no colder than -50, and seldom more hot than +70. The controllers on the machines ran the temps per the unit specifications.
They had large very expensive 440 volt compressors probably somewhat bigger than most car engines, and probably cost more, too.
The temperature had to change very fast, to properly prove the parts quality. There was a recorder on each machine. I watched mine very closely, and at any deviation no matter how small in the cooling or heating curve, i would call in a trouble report. Someone told me I was initiating half of the service calls in our entire department.
Ole’ Burt, one of the last of the great men of another generation would look at it and usually found a relay gone intermittent. And, he could tell which one, because by the recorder, he knew at a glance what the machine was doing.
I got transferred to another department and after the first month also had half the service calls in the new department. There were some angry people. Burt told them, “Please shut up and leave him alone. He calls in; I go out and replace a ten dollar relay and go back to the shop. The other half of the service calls each involve many hours replacing out a horribly expensive compressor, and that would not happen if everyone kept an eye on the recorder as he does. I have never had to replace one of his compressors. He is doing what everyone should be doing.”
He once told me that he was convinced if he adjusted the span on all the recorders so they just showed a straight line down the middle of the chart, half the techs would never notice. And, these were some of the best electronic technicians in the world. The problem was, they were electronic technicians, not heating and cooling technicians.
So, I do believe most folks don’t pay much attention to their car gauges. I, ahem, do, and thus resent not having gauges.
