Will I damage my vehicle, a 2003 Cadillac Seville, If I install 4 225/60R16 tires instead of the OEM 235/60R16 tires? The 225’s are less than 1/2 inch in diameter smaller than the 235’s.
What does your owner’s manual say about the proper tire size?
I don’t know if it they will cause any damage, but they will lead to inaccurate speedometer and odometer readings. The odometer will read more miles than you actually put on the car.
Why not just go with the proper size?
This post is also in the Repair and Maintenance section.
