what could be causing a poping sound when backing up? jacked the back up and looked under the van and can’t see anything that would be causing the poping noise. wheels rotate ok and arent’t loose, might have a small bit of slack in wheels bearings, but thats normal, no noise coming from the bearing. can,t find the cause.
Related topics
| Just started popping noise | 2 | 738 | February 22, 2011 | |
| Noise from back wheels | 2 | 432 | May 14, 2009 | |
| Noise when backing up | 0 | 238 | February 23, 2010 | |
| Popping sound in right rear wheel area has mechanics baffled | 5 | 11085 | April 24, 2012 | |
| Popping noise | 1 | 319 | October 9, 2007 |
