No start 1994 Suburban
So I have a 1994 Chevrolet Suburban 5.7
Craziest thing is it will start and run fine only once a day after that the engine will turn over but I have no spark. Fuel is spraying in the TB. Changed coil, icm, ecm, rotary button, cap… any ideas?
Did you test the ignition module?https://easyautodiagnostics.com/gm/4.3L-5.0L-5.7L/distributor-mounted-icm-tests-1
Since you’ve already replaced the Ignition Control Module, try replacing the distributor pickup coil.
