I think it was Mountainbike (is that the right name?) who said:
" Air comes in to replace the displaced gasoline through the charcoal bed in the charcoal canister.
If the charcoal bed were ulling water it would saturate and choke the pump off. Wait a minute, perhaps that’s the answer…I’ll post at the thread’s end so this doesn’t get missed."
What seems to have been the problem is a small plastic box - about the size of a cigarette box, with one end opened and a small hole at the opposite end. The semi-closed part is sort of slanted (like a lean-to hut).
This small plastic box is mounted inside the rear bumper.
Neither I nor the independent mechanic are sure of what this little plastic boxes function is, but a vacuum hose of some sort leads from it to the CHARCOAL CANNISTER.
Now the charcoal cannister seems to draw air through this little plastic box - which was filled with leaves and other debris-causing it to stop-up.
Apparently, water has been draining over the rear bumper and somehow, ending up in this plastic box.
Now the charcoal cannister seems to have been sucking water from this plastic box. It also seems that the cannister continued to suck any and all water that cascaded over the bumper. The independent mechanic said that he found no less than FIVE GALLONS of water in the gas tank!
We have not finalized the problem or the fix. This charcoal filter does seem to be at least a part of the problem.
Now, on to Nissan. It just seems to me that after the 2nd report of water in the gas (and certainly by the 3rd or 4th reports) - Nissan’s EXPERT should have at least thought about this.
I’ll post more tomorrow when I have more facts.
Thanks again to everybody who read my thread and offered valuable constructive advice!
RB
One more thing: is there any way to post pictures in this forum?
