When replacing the battery in my 1997 Quest, I mistakenly reversed the polarity and hooked positive to negative.
Have I completely destroyed the electrical system? The only thing that works now are the headliights.
If you’re lucky the fusible links burned out and saved the rest of the electrical/electronic components. Check the main fuse panel under the hood.
Hope and pray the damage is limited to these links.
