About the early days of CD’s. Recording masters made during the vinyl/magnetic tape era had a bias in them to compensate for the natural fall off in frequency response of a record or tape. On high end equipment of the day, this resulted in a pretty accurate reproduction of the original.
Then CD’d come on the scene with a table top flat frequency response from 20Hz to 22kHz. When played on a cheap boom box, this actually worked because he speakers weren’t all that accurate, but add a CD player to a high end system of the day and the sound was “unnatural”. Newly recorded music and many of the old master recordings have been modified so that the CD’s sound more natural now. I guess you could rack that up to the teething process for the CD industry.
"Me explaining that even after a single play, the loss of quality of a diamond tipped need tearing through vinyl degrades the content unacceptedly"
I take issue with this, mostly to the word “unacceptably”. There were two grades of vinyl recodes made back then, similar to coin production, you have the “proofs”. each record mold could stamp out only so many records before the mold started to degrade, so the first run records were the audiophile grade, after that came the less expensive consumer grade.
A cheap record player of the day would do a lot of damage to the groove even after just a few plays, but a lot depended on the how new the needle was. The cheaper record players put a lot of pressure on the needle, but most of those needles were round so they had more surface contact area to support the extra weight.
On the higher end equipment, the stylus was elliptical shaped to increase frequency response, but the tonearms had much less tracking force. As long as the stylus had smooth edges, most of what it did was to temporarily distort the groove. If the stylus started to develop a sharp edge, which they could as they aged, then they would actually begin to shave the vinyl, wiping out the highest frequencies.
What you did not want to do was play a record over and over. The vinyl needed time to rest and recover, at least that was what I was told by audiophiles that I knew back then. But even with the best turntables, tonearms, cartridges and styli of the day on audiophile grade records, there was a tiny amount of degradation with each playing, but it hardly made the recording “unacceptable” after a single playing. With proper care, a record was still acceptable after hundreds of playings on reasonably good equipment.
