dodge caravan with the 3.0lt engine replaced the old fuel pump because after removing the fuel line from the supplie side of the filter you could here the pump run but no fuel pumping out so I replaced the pump and filter still no fuel but can here pump running.
jasonj
1
Did you check the line for blockage? I’ll bet one of the fuel lines has collapsed inside.
Related topics
| Longer cranking after fuel pump & filter replacement | 4 | 882 | February 23, 2010 | |
| Fuel fill up problems | 4 | 636 | December 16, 2009 | |
| 1993 Ford Escort fuel delivery | 8 | 2809 | May 14, 2011 | |
| Gas leak in 2005 Caravan | 29 | 20088 | July 16, 2016 | |
| More information on he Wagon. STILL stuck | 9 | 1071 | January 1, 2010 |
