I need to know the alignment of an engine as my time belt is broken
The alignment is side to side… but that won’t help a broken timing belt.
What is it you really need? This?
Might look here as well…
A good mechanic should be able to read the specifications and reset the cam before installing the new timing belt, idler, tensioner, and water pump. Hopefully, this engine is not an interference type as this means more expensive damage, probably not worth the value of the car. Interference means that the spinning engine has hit the stopped valves and bent them or (worse) punched through a piston.
The 2003 KIA Rio 1.6 L 4 cylinder engine is an interference engine.
If the timing belt broke , more than likely valve damage has occurred.
