Need help with codes
Can someone help me and tell me what these codes mean?
Your pictures aren’t showing.
Here is some info on P1882 (the CAN STD FAST isn’t a code, it’s an indication of the communication protocol your car uses):
Thank you ill check it out
Internet access but can’t google. That is strange.
And the “codes” in the first picture you posted aren’t codes- they’re menu options. Click on them, and in the new screen if DTC is listed, select that to get the actual code.
Model year and engine?
“CAN” refers to the type of compuer network the car uses. Like “LAN” (local area network) is used for desktop computers. I’m not sure what the C means, but I just think of it as Car Area Network.
