I have a 94 dodge spirit and a few weeks ago I was going too fast on some ice and when I applied the brakes the tires locked up and when I got off the ice the tires grabbed and stopped me. Since then I have had a wobble coming from the front passenger tire. It started out small and has been getting worse. I had a similar wobble a few years ago and it ended up being a broken tie rod. At first I thought that I just had some snow/Ice jammed in the rim but it has warmed up enough that if that was it then it would have melted by now. Any suggestions? And should I take it in as soon as I can? I drive 2 miles each way to work and that is about all I drive it. Thank you for any help.
Yes, get it checked asap. meanwhile drive slow. very slow.
