My honda civic
Hello there
Can someone help me how to bleed air out of my power steering system
Because i change my power steering pressure holes since then i hear some noise in the car like air down the steering also the motor makes noise
Have you tried removing the filler on the ps pump and slowly turning the steering wheel all the way to the left, then all the way to the right, that sequence 3 or 4 times? When parked? Takes about 10 minutes. If you haven’t tried that, probably worth a go. Check the fluid level and top off if required after each sequence.
If there is air in the power steering system it is under filled.
Shut off the engine, wait 10 minutes for the air bubbles to rise and escape the fluid. Refill the reservoir, start the engine, turn the steering all the way to the left and to the right. Turn off the engine and check the fluid level.
