it is stolling and dieing and blowing white smoke out of the manefold and shooting my dipstick out and when i give it gas it dies only when its in gear tho
sounds like you have to much crank case pressure.try replacing your pcv valve.
White smoke suggest water or anti freeze in the exhaust or a head gasket leak. Check your oil and make sure there is no anti freeze in it. It will show as small droplets on the dip stick, as water and oil don’t mix. Check both the overflow tank and radiator and make sure the level is not droping.
Unfortuantly the head gasket is a major repair. it is easier and less costly if you have the 4 cylinder.
Good Luck
