My car won't drive forward but is able to go in reverse
2008 Ford Fusion 153km
Is the Check Engine light on?
No just the wrench symbol w/e that mean
That’s the same as a Check Engine light.
You need to have the code(s) pulled to determine the cause of the light. It could be the reason why the transmission isn’t shifting correctly.
Do you know anyone with a code reader that can come over add pull the code(s)?
