I drive a 2005 Nissan Altima, and it’s repeatedly had a strange problem. Sometimes it will sputter and stall out. It only happens when I’m exiting off the interstate, after driving a higher speeds (65+). It doesn’t happen every time, but it seems like it’s more likely to happen the longer the distance I’ve gone (shortest distance was about 25 miles, and that’s only happened once). The check engine light never comes on. We’ve taken it to the mechanic, and they can’t seem to figure it out. They tried replacing the cam shaft sensor, but the stalling still happens.
Also, there was a recall having to do with the computer that we already had fixed. The engine would just shut off while driving. Very scary if you’re going 75 on the intersate. But that hasn’t happened since we had the computer recall addressed.
Any suggestions for the stalling problem? And do you think it might be related to the recall?
