JMHO, but I’m not sold on the idea of this many bad distributors. Especially since you’ve had this done at a number of different shops and if you have also related to each shop in succession that you have had repeated dist. failures.
Maybe each shop is just assuming it’s the same old thing and blindly replacing the distributor when the problem is really elsewhere; like a failing fuel pump.
