I have a 95 Eledrodo, when I excelerate the engine misses as if you are cutting the key on and off realllll fast. While driving down the road occasionally I feel a slight miss. After the engine is warm up to normal operating temperature and it has sat for 45 min or so, when I go to start it, the motor spins and spins and spins before it fires up. When the engin is cold, the motor fires up like it should. I’ve replaced the ignition control module, coils, spark plug wires, spark plugs, map sensor, crank shaft sensors (both of them) and the cam sensor. NOt sure what it is obviously. Apprecial any help you can give.
Thanks
