Which, if any, year or otherwise models of Mini Coopers absolutely require premium fuel?
I have just sent off that very question to Mini Cooper via their website.
please post any reply you get here.
will this web site help?..http://www.mpgomatic.com/mini_cooper_mileage.html
I’m pretty sure they all require it, but definitely the S and JC Works models will. The compression ratio in the base model is 11:1, so it’ll prolly need premium as well
edit:
The cooper base has a 10.6 gallon tank while the S model has 13.2 gallon tank. So, even if the base model needs premium, you’re only gonna spend a whopping TWO DOLLARS more per tank than regular
