I have a 97 Nissan Maxima. When I make a slow left turn, I can hear a metalic rubbing sound coming from the right side of the car (possibly right front). I don’t hear any sound when I turn right. I am sure the sound is probably there when I am going faster on the left turn, but I just don’t hear it. After I straighten out from the turn the noise is gone. Is it brakes, wheel bearing, struts, others? Thanks!
“Is it brakes, wheel bearing, struts, others?”
Maybe.
There are too many things that can make noise up there. It needs an actual visual inspection so you’ll need to just take it to someone - preferably a local, independent mechanic.
