Today while driving suddenly i heard a metal scratching sound on the road, i stopped the car and looked then I found that there was 2 feet metal rod dangling. Now what I am not sure is, if this rod belongs to the car or roadside debris got stuck into my car bottom. That rod came out when i just moved a bit … i cant see anything to fix it as well. Any help/pointers will appreciate.
That does not look like a car part.
Looks more like a lawn mower part than a car part. What happens a lot is you hit stuff with the front wheel, particularly on the side of the shoulder, then the front tire throws it to the rear or the rear tire. Nice that both ends were looped anyway.
Agree with others that said it does not look like a car part.
Has anyone complained about getting static shocks getting into and out of the car? If so, that might have been an attempt at a solution. The idea is, car develops a charge as tires roll along the ground, losing or gaining electrons along the way… The extra charge gets put back into the ground by that rod so you don’t get shocked when you get out. The rod (wire) is initially configured so one end slightly rubs on the road surface; but this method usually doesn’t work at solving the shock issue so I’m guessing somebody just bent the rod up so it wasn’t in the way.
Gas trucks used a chain dragging or looked like leather strap. If it was a used car maybe a cat theft deter ant by an idiot.
Another interesting idea, George, but I really doubt this was a static dragging rod bent out of the way.
I have seen trailer safety chains dragging on the road, an interesting sight at night.
A fuel truck dragging a chain on the pavement sounds like a fantastic idea.
Maybe brass but you can get the straps fo $10 on Amazon. I think trucks use a grounding wire now.
Grounding to what? the only ground that counts for static electricity is to earth.
Interesting if you get beyone the automatic chain paragraphs. Gee I guess I really did see chains and straps dragging from trucks when I was a kid.
Yeah, they were common when I was a kid too. There was a lot of concern about fuel trucks and static buildup going down the road but that has since been disproven as a risk.
However, they must use a bonding wire to ground when transferring flammable liquids to/from the truck. Static can build up from driving down the road as well as when the fluid is passing through the hose. There are special materials to minimize the triboelectric effect but they are far too expensive to use in fuel trucks when a simple grounding wire will work and has some visual feedback from the circuitry monitoring it.
I still see Electric Company trucks with lifts that have grounding straps hanging down. The carbon black in the tires is not sufficient to ensure the truck frame will be safe if the bucket comes near or touches a line.
