Does anyone recommend a good car mechanic- especially for manual/stick shift cars by Fort Bragg Army Base, North Carolina.
There use to be one on Base. Are there still the rent-a-bay garages on base that you can use…Most had qualified mechanics to help out with any repairs…or even do the repair.
I looked on the Cartalk mechanic finder, an the first one to pop up was Wardlaw trasnmission. Only on comment, but a positive one: “Mr. Wardlaw is a retired SF Sergeant Major. Although it’s a transmission shop, they’ll pretty much work on anything. Interesting part is if they don’t know how to fix something, they’ll go to the public library and borrow the tech manual and figure it out. The guy is so well known and respected, that he does not advertise. He’s not in the yellow pages at all. I take my older car there (93 Taurus) whenever something needs done that I can’t do. He’s done front-end work (replace control arms and sway-bar link assemblies), brakes, and a switch in the sterring column on the Taurus. He’s a straight-shooter.”
You’ll find more here, just put in 78310 for the zip: http://www.cartalk.com/content/mechx/find.html
Thanks- found a good mechanic at Firestone on post at Fort Bragg. All set:)
