Maintaining the running position
car will start for a brief second unless you pump the gas like its going out of style. can you help me out?
What year and how many miles on your car? Does it drive normally after the start? When was the last time you changed the fuel filter?
its a 1994 and has 77,000 miles. It does not drive after the start as it does not run long enough. I however did drive it about 70 miles before the problem started and it ran fine. it made no noises or anything other than having to pump the gas to keep it running. the fuel filter is brand new, the gas tank is brand new, the fuel pump is brand new, it has new spark plug wires and plugs.
Was all that done after you started having problems or was it done because of the problem and if not why was it done and was it done all at the same time?
