My question isn’t very based on a repair, but more of an electrical upgrade. I have IntelliBrite LED color changing Pool light and I wanted to put it to good use and actually put it under my car as an underbody effect. The light is a 12 volt and my battery is 12 volt. I wanted to know if I hooked it up into my battery if it would…
FIrst, I’m not certain why you would want to do this. However, if the LED does not draw a lot of power, I suppose you could connect it to the tail light circuit so it would go on and off when you turn on the headlights. I would put a low amperage (1 or 2 amp) fuse in the line to be safe.
I remember back in the late 1940s watching cars go down our street when I was a kid and some cars had a light under the car. My first car, a 1947 Pontiac did have such a light, but there was no lens or bulb in the socket. I didn’t know the purpose back then, and I still see no reason for it. On my old Pontiac, it looked like it came that way from the factory.
So if I hooked it up to the underbody of my car and connected it to my battery and hooked up a switch that turns the light on and off, it should work no problem? Or should I connect it to the fuse box and add another inline fuse? I have no clue. And there is so way I could damage my electrical system in my car?
