I’ve been having trouble with the cooling system of my 2005 Kia Sedona (about 90,000 miles) and a couple months back I had the system flushed, coolant added and thermostat replace. Not long after this the overheating started up again. After the first five minutes of driving, the thermostat starts creeping up above the half way mark and within about ten minutes it hits the H. My vents also don’t blow heat. After ten minutes the heat SOMETIMES suddenly kicks in after the needle hits H, but it’s kind of inconsistent and sometimes I get no heat even after hitting H and sometimes I get a little heat and then it goes away. I only drive it 15 minutes each way so am not sure what would happen if I kept driving.
Anyway, I took it back to the shop and they did a pressure test and said they thought it was a leaky head gasket and that they couldn’t do the repair and I should take it to a Kia dealer. I picked it up and on my way home I noticed I was getting heat from the vents immediately and the thermostat stayed at the halfway mark. No overheating. Is it possible they are wrong and the pressure test knocked some air out of the system and that the test actually fixed the problem? Can a pressure test give a false result?
Anyone with any experience or insight here? Thanks in advance!
