Jeep grand cherokee overheating
MY JEEP OVERHEATS WHEN i COME TO A STOP WITH THE ENGINE RUNNING AND COOLS BACK DOWN WHEN i START MOVING AGAIN.
Hey Glenn, You Forgot To Introduce Your Jeep!
Give us some more information. How about year, miles, engine, transmission, and whatever else you’ve got.
Describe how you know it’s overheating, please.
Have you checked the coolant level or anything else?
Engine belt(s) still on and not slipping?
2000 JEEP GRAND CHEROKEE LARADO, 121,000 MILES, 4.0 ENGINE, AUTOMATIC 4 SPEED TRANNY, iT WILL RUN GOOD WHEN YOU FIRST START IT, THEN IT STARTS TO HEAT UP ABOVER 210 REACHING THE MAX OF 240 AND ABOVE IF LEFT RUNNING LIKE WHEN AT A RED LIGT OR JUST IDLE, WHEN i ACCELERATE IT COOLS BACK OFF, i NOTICE THE FAN IS NOT KICKING ON.
That’s your problem. If that fan doesn’t kick on, there’s no air passing through the radiator to cool the coolant when sitting still. Check the fan motor and the fan relay for proper operation.
THANK YOU
I had the same problem with my jeep. The fan relay is in the front passenger side quarter panel behind the lights. A pain to find and fix. The mechanic wanted to slap the engineer on that one.
