Is this a rod knock? Ticking noise (video)
04 kia amanti
Ticking noise on cold starts after not driving for a few days. Usually it goes away within a minute of a cold start but it lasted 15 minutes today.
Ticking speeds up as I rev the engine. Already got oil change. Here’s short video. Seems louder under the car. https://youtu.be/AkS-RYLaxRQ
If it goes away after the engine warms up, then I think it is likely to be piston slap, which is… mostly… harmless.
Ive heard of stuff like engine restore. Should I pour some of that? Is this an expensive repair? Urgent? @VDCdriver
Sounds like a valve lifter has gone south to me. It might be best to pull the valve cover off and see if a lifter has collapsed or maybe been thrown out.
Hopefully this has not been going on long because one this noisy will damage a cam lobe, mushroom the valve stem, and so on. See if there is any excess movement in the rockers.
New lifters are about 10 bucks each I think.
That doesn’t sound line any knocking I’ve ever heard and I’ve heard quite a few. My best guess is the noise is from the valve train.
@Rod-Knox lol you should know right? Is this in urgent need of a fix? Recommend and additives?
There might be some hope for one of the “renew-zit” additives to help but I would recommend using a stethoscope to investigate the source to determine how critical it is.
I does sound a little like a collapsed lifter, but this engine has a history with a knocking sound after start up that gets progressively longer until it knocks all the time. The knocking is usually from the crankshaft bearings. It starts around 70k miles and by 100k, the engine will need a complete rebuild.
BTW, it is identical to the Mitsubishi 3.5 DOHC V-6, but the Mitsu uses better parts. Some rebuilders will use the Mitsu parts when rebuilding.
