2009 Suburban with intermittent instrument cluster problem
When starting the car the gauges and/or the cluster lights may not work. Problem can be fixed with a re-start. Or, it can be fixed by using the remote-start. When using the remote-start the cluster and lights will come on after you insert and turn the ignition key then press the brake pedal.
