Hi, just want to know how many quarts needed to replaced transmission fluid for 2006 Honda Odyssey? Its not indicated on the manual & service advisors are giving me different amounts. Pls. help. Thanks in advance.
On my 02 Sonata changing trans fluid is the same as changing engine oil, except that theres no filter to change.
I’m pretty sure your Honda is the same & theres no filter to change on it either.
I simply pulled the drain plug & measured the amount that drained & replaced with the same. In my case that was 5 quarts.
The folks at Hyundai are mighty proud of their “dealer only” trans fluid at 8 bucks a quart.
