How much horsepower?
1999 Ford F-150 6 cyl 4.2 how much horsepower?
Google much, typed your exact question
https://www.fordf150.net/specs/engines.php
How much horsepower does the 1999 Ford 4.2 6cyl f150 have?
So, You are too clueless to google the question yourselfand also too clueless to click on the link Barkydog provided.
I will give you a clue, the answer is palindrome.
OK you do not click on informative link provided, here ya go from the link, 205 @ 4950 RPM
Enough to make it move.
I cannot figure out the palindrome, the only one I like is the lake address 27172, works the same from either direction, ie a palindrome
Palindrome would be 202.
202 is what I got, and what I got when I clicked on Barkydog’s link.
A man, a plan, a canal, Panama.
205 HP @4750 RPM
260 Lb/ft of torque @ 3000 RPM
Compared to newer trucks it’s not very impressive, but back in 1999 it was on part with the other V6 options available in full sized trucks.
Not enough. Rarely is there ever enough.
