Granddaughter has a 97 Skylark that has no radiator cap,just a reservoir cap. I know I can drain it with the lower radiator hose but how do I flush and refill it?
The most straightforward thing is probably to use one of those flush & fill kits - they come with instructions for various radiator set ups.
But it still must have a reservoir. That is normally where you’re supposed to fill those things - I think.
My daughter has the same car. See if you can get a Haynes manual or similar, library’s usually have them. The Haynes manual says to disconnect the reservoir and use a garden hose in the top of the radiator until the bottom drains clear. Cigroller makes a good point to get a kit as the garden hose won’t clean out the passages in the engine.
Thanks, that makes sense.
