How do you drain a Taurus radiator? Where do they hide the petcock or plug? Is it okay to use radiator flush with antifreeze or can you only flush in warm weather?
Some cars don’t have petcocks. In this case you remove the lower radiator hose to drain the coolant. Messy, but expedient.
What is “Radiator flush with antifreeze?” I always thought a cooling system flush was just with water. Warm, cold, I don’t think it matters.
Others will correct me if I’m wrong.
Like with any opportunity, someone will fill a vacuum. The auto part stores generally have some sort of mouse milk to add to the water when flushing a cooling system. Some may help, some may damage. I suggest just using water.
