My 1996 Toyota Tacoma with V6, manual transmission and 4WD has a problem with idling when hot. It almost always occurs after I drive for a bit, shut the engine off, then restart it. At this point the idle speed is very low and it will die if I don’t keep the engine speed up by using the throttle. The check engine light is not on. Any ideas? Thanks
Related topics
| Fix for Temperature Issue with 1996 Toyota Tacoma | 6 | 4099 | October 10, 2013 | |
| Hard starting Tacoma - Hot and Cold | 4 | 9910 | February 15, 2012 | |
| 99 Tacoma Six Cyl. Stalling During Idle at Traffic Lights | 2 | 675 | February 28, 2011 | |
| Idling Problem | 5 | 1235 | October 24, 2011 | |
| 96' tacoma has trouble starting in hot weather | 1 | 427 | July 25, 2009 |
