I own a small all-electric car; Kurrent.
When I turn on the running-head lights-rear lights for night driving the speedometer now doesn’t light up and is making a high pitch monotone sound. The radio flashes pulses but does not come on when the headlights switch is turned on. A crossed circuit wire or switch?
My car is very basic assembly.
Also one rear light is brighter than the other when I press on the brake pad. When the lights are on for night driving only one side illuminates brighter when I step on the brake.
Thought I’d ask you. THANKS, jay
http://www…D8F0a2rqn0
Replace the rear combination bulbs (brake - tail) lights. That is part of your problem. I would guess the rest of your problem (I doubt if replacing the lamps will fix everything, but maybe) is a bad connection, likely a ground wire not making good contact.
