Help!!! (please)
I have a 1986 Toyota Camry. I just replaced the battery,4 tires, wheel barrings, wheel cylinders, tie rods, brakes, hoses, had a radiator pressure check and transmission service. Pretty much everything has been gone over, The only thing left to do was to have my exhaust ?pipes (the whole assembly under the car) welded back to the body as it has come loose. I spent everything I had to get this car in good shape so I can drive home (Oregon to So.Calif) to care for my dad who’s very ill. I will be traveling through the mountains, in snow, alone and, other than the minimal roadside assist. i have through my (cheap) insurance, I’m on my own (a 52yr.old woman who’s never even changed a tire)…
Other than the rattling, the car was running pretty good until I parked it for three days and it rained and dropped below freezing a couple nights (or got really cold). I don’t have much antifreeze in it yet (mainly because the radiator is full and I didn’t know how to fit a gallon of antifreeze in there).
anyway, when I started it, it started fine (great battery) and if I don’t apply any gas it idles somewhat ok (drops in idle speed alittle but picks back up) BUT as soon as I apply the gas pedal, it dies. I have tried to warm it up a while, I’ve babied it, I’ve pumped it -tried everything and it still dies as soon as I apply the gas. I can go a few hundred feet maybe then it will die but as long as my foot is not on the gas, it’s ok. I’ve never driven this car in cold weather and it’s fuel injected so I never thought it needed to warm up before driving it…
The check engine light comes on only when I’m starting the car but goes off as soon as it starts. The idle doesn’t change much when I put it in gear until I apply that gas. I’ve had a (mechanicly inclined) friend look at it and he said it wasn’t misfiring nor did it have any visible signs of bad hoses or leaks or bad plugs (even tho. one plug does have black tape around it???) he said it looked good. He did replaced the fuel filter that day as the old one was pretty plugged. I blew through both and could tell the difference somewhat. So, thinking it was fixed, I drove him home (about a mile) without stalling and it sputtered some but seemed much better (or it didn’t die) but in one mile, the temp. guage moved quickly to HOT. I got it down by turning on the heater. I had already checked the water and it was full, couldn’t figure that out either. Could it be frozen (deep inside the motor) and get hot like that???. I have had a new thermostat put on as well, about 4months ago. So, I came home and I again left it parked for two days while it rained and was pretty cold until today, I got in it and it did the exact same thing…would start, idle then die when I applied the gas…
So, obviously, I still have to get that exhaust thing welded and I called my mechanic (who lives about 20miles from me and is without transportation himself right now). He said that the exhaust system (specifically the EGA valve or sensor) comes after the engine and shouldn’t affect the motor like that. He suggested maybe the O2 sensor but what is baffling is that the problem occurred after the car sat for days…it ran fine before I parked it and it rained and got cold so I’m thinking ?? maybe the water is frozen in the motor? or maybe theres some water in the gas ?? Nothing really broke while driving. It all began after being parked for several days in the rain and first (real) cold days since I’ve had it (and, what really is upsetting is this has only been a week since getting it back from my mechanic after all that money I spent on “getting it reliable” for the trip).
So, please, if you have any ideas, DIY preferably, starting with the cheapest and easiest solutions, please tell me. I am so stressed about this trip and I’m suppose to leave by the 1st of Dec. and I’m praying this is something easy and cheap to repair… Please, any and all suggestions will be greatly appreciated.
