I’m trying to figure out when a show aired, so I can download the archived broadcast. Unfortunately I can’t remember the caller’s name, but here’s the details of what I do remember.
The caller called in, and it was diagnosed as a drive shaft problem, and Tommy gave her the worst case scenario, referencing the Olympics and Mitzi Gaynor (?), stating that the worst case scenario was that the drive shaft would disconnect from the front end, causing the car to go end over end while she was inside.
If any of you know when this aired, I would appreciate it. I’m pretty sure it was either in 2008 or 2009.
Never mind. I found it. March 7, 2009
