Headlight adjustment screws/bolts - where are they located in my 2005 Toyota Camry?
The screws are likely located at the rear of the headlight housing and are perpendicular. I recall the last that I adjusted required a torx socket.
My Haynes manual says that models after 2002 have no horizontal adjustment. For vertical, Haynes’ photo shows an adjusting screw next to what appears to be the neck of the windshield washer fluid reservoir. The manual says to raise or lower the beam by turning the adjusting screw. The caption on the photo says you can turn the bolt head with a wrench or engage a screwdriver with the adjuster teeth. (Maybe it’s like the star wheel on a brake adjuster.) I guess if you can find the adjuster next to the reservoir, then you can use that as a guide to find the one on the other side.
