I have a 2005 Camry with about 199k miles. 2AZ-FE engine (2.4 L) and U250E Automatic Transmission.
Related History:
Upper Dog Bone Mount - Replaced at 160k
Transmission Filter Drain and Refill - 186k
Alternator - Replaced at 193k
Serpentine Belt - Replaced at 196K
Serpentine Belt Tensioner - Replaced at 194k
Motor Mount on Engine - When I replaced the tensioner, had to jack up engine looked OK
Front Motor Mount - When I replaced the tensioner, had to jack up engine looked OK
Transmission Motor Mount - Last time I did oil change and rotated tires (195k), I don’t recall it looking bad.
You may have to turn up the volume to hear the issue I’m describing.
20 Seconds - Rumble when going into reverse from park
35 Seconds - Going into Neutral
38 Seconds - Going into Drive, also a slight rumble
43 seconds - going back into Neutral, RPM goes up you can hear it
44 Seconds - Going back into Reverse, rumble and grinding sound
1 Minute - Turning on AC - Loud rumble, seems to be coming from front right of the car, lasts for a few seconds and goes away
When going into reverse from park and not moving, I’ve noticed a rattle sound. Has been this way for a few years, and I’ve just ignored it, as I couldn’t identify the source. However, it seems that the issue is getting worse.
On a cold start (and only a cold start), with my foot on the brake, and going from Park to Reverse I notice the rattle sound I typically do. While in reverse and turning on the AC I hear a loud rumble sound. This only happens on a cold start. As you can see in the video, the rumble goes away after the AC has been on for a few seconds. I get nice cold air. I do not hear the rumble when going into reverse after the car has been driven for a bit. It seems to only be an issue at cold starts. If I’ve been driving for a bit, and turn on the AC, no loud rumble.
I’m not sure if I should just ignore this issue or try and fix what’s causing the rumble. Any suggestions on what it could be, or how to further diagnose, would be appreciated.
I recently checked the power steering and coolant reservoirs, and they are nice and full.
Maybe the rumble when going into reverse, and the rumble with the AC on for a few seconds are unrelated problems, I don’t know.
Thanks!
