wesw
July 9, 2014, 7:15pm
1
while I m working under my jeep I m cleaning excess grease/oil/dirt accumulations and greasing fittings
the problem is that while my numerous universal joints have grease fittings, my gun tip won t fit in to the fitting on them.
is there a special tip I can use or do I have to do some disassembly to access them?
Here a $30 adapter kit from Autozone, looks like it has some small-diameter ones for situations like yours:
http://www.autozone.com/autozone/accessories/OEM-11-pcs-grease-gun-accessory-kit/ /N-25s4?itemIdentifier=978118_0_0
wesw
July 9, 2014, 7:25pm
3
thanks, I have some plastic air hose fittings I may be able to rig
wesw
July 9, 2014, 7:29pm
4
can t really afford thirty bucks right now, but if I could find a single fitting…
wesw
July 9, 2014, 7:31pm
5
maybe a piece of fuel line…with weed wacker fuel line stuck in… lol
Harbor Freight might have it for much less…
Usually the drive shafts can be rotated to a position where the alemite is accessible.
wesw
July 9, 2014, 8:36pm
8
lol ale mite be accessible but I don t drink…
Grease Gun Needle Adapter…
Agree with Caddyman, 54 to 58 years ago when I greased cars we used a needle gun to grease u-joints. I especially remember a customer that had a 37 Pontiac because it had 37 grease points.
Nobody even remembers what a pneumatic grease gun sounds like any more…
@Caddyman ; Puttchewww, Puttchewww, Puttchewww, Puttchewww,
Yosemite
Use Model 83278* from Lincoln Lube Equip. Attaches to end of grease gun.
