Do I need to grease my end link kits?
I got these new end links online and the image didn’t show any graese fitting on the end but I got them today and there is a grease fitting. So I’m not sure if this means I need to add grease? Is there a way I can make sure? The boots are sealed so can’t look inside either.
Anytime you get a new component with a grease fitting, you add grease.
Well then I guess ima buy a new tool today haha.
Grease until is spurs out?
Also, any type of grease specefically I need?
Go to the parts store and get this kit.
Pump grease in until the rubber boot swells.
Found this at my local store in Canada! Looks like yours should be good?
http://www.canadiantire.ca/en/pdp/mini-pistol-grip-grease-gun-0282714p.html#srp
It’ll work.
Get a grease gun with a whip hose, trust me on this. It can be a cheapo, you won’t be using it often.
use NLGI #2 grease . . . very common. Many of the grease cartridges will reference that standard
