I have a 94 GrandPrix SE and when the car is started it will not engage in gear till the start in 2nd gear swith is engaged. Is this a problem with the transmission or a problem with the switch? Anyone have experience with it? I understand that this car has chronic transmission problems.
Haven’t heard that this model has chronic transmission problems.
A transmission filter and fluid change could help a delayed shift. THAT transmission may have the original fluid and filter. That wouldn’t be good.
