I have reservations regarding the engine management system. As I recall, this type of program was attempted in the 1970’s but was discontinued. I’m particularly concerned with the shift from 8 cylinder to 4 cylinder which will definitely cause a significant temperature differential between the ADJACENT cylinders that are functioning and the ones that are not. Does this lead to gasket expansion/contraction to cause leakage between cylinders? Does this lead to problems with engine heads, especially if the head is aluminum? Finally, is there a software program available to bypass & eliminate this function.
Things have changed a lot since the 1970s. Those early attempts at cylinder deactivation were a disaster, but today’s systems are significantly improved. I’m not aware of any problems caused by the latest versions of this technology, and I certainly can’t see why you’d want to bypass it.
Saving fuel is a good thing.
Oh, I just remembered, there was a guy last week who wanted to bypass it because he had a loud exhaust system on his Hemi-powered truck and thought it sounded wimpy when it was running on less than all eight cylinders.
“Oh, I just remembered, there was a guy last week who wanted to bypass it because he had a loud exhaust system on his Hemi-powered truck and thought it sounded wimpy when it was running on less than all eight cylinders.”
If I recall correctly, we advised the Hemi guy to appear on Dr. Phil’s program.
You know–the episode dealing with men who are extremely insecure about their masculinity.
I conclude the public does’t believe that the manufactures will not continue exposing us to “bad” technology.
Of course the people who designed the early cylinder deactivation systems are retired by now but we still fear that the mind-set that allowed this to happen still exists,paticulary at GM.
I can’t say why,perhaps I have been “affected” by advertisement but I don’t fear that the Japanese would so easily allow bad technology to make it all the way into production. Have I been mislead?
iirc the cylinder deactivation alternates the cylinders that are deactivated to keep the very problem that you are fearing from happening. Also, As far as thermodynamics is concerned, and aluminum head/block would be better equipped to handle the temp difference as it it’s more conductive than Stainless steel or iron.
With all due respect, you’re clinging to a 40 year old example of questionable technology. I’ve been burned a number of times when I ventured too close to the bleeding edge but I’m not about to condemn a modern implementation because it was tried 40 years ago and didn’t live up to expectations. If you’re risk averse, do what I do- sit back and wait until the bugs are ironed out or enough guinea pigs buy in and have no problems…
TwinTurbo makes an excellent point. When new technology is introduced, it tends to be very expensive and it can be prone to problems. If you wait a couple of years before buying new technology, you usually wind up with a more reliable product, at a cheaper price.
You didn’t say anything at all about the vehicle. There may be performance software available that, among other changes, deactivates the system, but if you have a new vehicle you’re sure to void the warranty by doing so.
If you’re looking at vehicles and this is a concern, I’m sure there are other selections in the group you’re researching that don’t use the technology.
I thought the GM system, like the Chrysler system, the same cylinders are always deactivated. However on the Chrysler system, cylinder temperatures are monitored and will deactivate the “MDS” mode when the variation between cylinders gets to high. I think the GM system would be similar.
I found info for the system. It uses time to even up cylinder temperature variations. (10 minutes in V4 mode, 1 minute in V8 mode.)
Re: Active Fuel Management
Cylinder Deactivation (Active Fuel Management) System Description
To provide maximum fuel economy under light load driving conditions, the engine control module (ECM) will command the cylinder deactivation system ON to deactivate engine cylinders 1 and 7 on the left bank, and cylinders 4 and 6 on the right bank, switching to a V4 mode. The engine will operate on 8 cylinders, or V8 mode, during engine starting, engine idling, and medium to heavy throttle applications.
When commanded ON, the ECM will determine what cylinder is firing, and begin deactivation on the next closest deactivated cylinder in firing order sequence. The Gen IV engine has a firing order of 1-8-7-2-6-5-4-3. If cylinder number 1 is on its combustion event when cylinder deactivation is commanded ON, the next cylinder in the firing order sequence that can be deactivated is cylinder number 7. If cylinder number 5 is on its combustion event when cylinder deactivation is commanded ON, then the next cylinder in the firing order sequence that can be deactivated is cylinder number 4.
Cylinder deactivation is accomplished by not allowing the intake and exhaust valves to open on the selected cylinders by using special valve lifters. The deactivation lifters contain spring loaded locking pins that connect the internal pin housing of the lifter to the outer housing. The pin housing contains the lifter plunger and pushrod seat which interfaces with the pushrod. The outer housing contacts the camshaft lobe through a roller. During V8 mode, the locking pins are pushed outward by spring force, locking the pin housing and outer housing together causing the lifter to function as a normal lifter. When V4 mode is commanded ON, the locking pins are pushed inward with engine oil pressure directed from the valve lifter oil manifold (VLOM) assembly solenoids. When the lifter pin housing is unlocked from the outer housing, the internal pin housing will remain stationary, while the outer housing will move with the profile of the camshaft lobe, which results in the valve remaining closed. One VLOM solenoid controls both the intake and exhaust valves for each deactivating cylinder. There are 2 distinct oil passages going to each cylinder deactivation lifter bore, one for the hydraulic lash-adjusting feature of the lifter, and one for controlling the locking pins used for cylinder deactivation.
Although both intake and exhaust valve lifters are controlled by the same solenoid in the VLOM, the intake and exhaust valves do not become deactivated at the same time. Cylinder deactivation is timed so that the cylinder is on an intake event. During an intake event, the intake cam lobe is pushing the valve lifter upwards to open the intake valve against the force of the valve spring. The force exerted by the valve spring is acting on the side of the lifter locking pins, preventing them from moving until the intake valve has closed. When the intake valve lifter reaches the base circle of the camshaft lobe, the valve spring force is reduced, allowing the locking pins to move, deactivating the intake valve. However, when cylinder deactivation is commanded ON, the exhaust valve for the deactivated cylinder is in the closed position, allowing the locking pins on the valve lifter to move immediately, and deactivate the exhaust valve.
By deactivating the exhaust valve first, this allows the capture of a burnt air/fuel charge or exhaust gas charge in the combustion chamber. The capture of exhaust gases in the combustion chamber will contribute to a reduction in oil consumption, noise and vibration levels, and exhaust emissions when operating in V4 mode. During the transition from V8 to V4 mode, the fuel injectors will be turned OFF on the deactivated cylinders. The ignition system secondary voltage or spark is still present across the spark plug electrodes on the deactivated cylinders. If all enabling conditions are met and maintained for cylinder deactivation operation, the ECM calibrations will limit cylinder deactivation to a cycle time of 10 minutes in V4 mode, and then return to V8 mode for 1 minute.
Switching between V8 and V4 mode is accomplished in less than 250 milliseconds, making the transitions seamless and transparent to the vehicle operator. The 250 milliseconds includes the time for the ECM to sequence the transitions, the response time for the VLOM solenoids to energize, and the time for the valve lifters to deactivate, all within 2 revolutions of the engine crankshaft.
The cylinder deactivation system consists of the following components:
? The VLOM assembly
? Eight special valve lifters, 2 per deactivating cylinder
? The engine oil pressure regulator valve for cylinder deactivation operation
? Gen IV cylinder deactivation engine block
? The ECM
Valve Lifter Oil Manifold (VLOM) Assembly
The cylinder deactivation system uses an electro-hydraulic actuator device called the valve lifter oil manifold (VLOM) assembly. The VLOM is bolted to the top of the engine valley, below the intake manifold assembly. The VLOM consists of 4 electrically operated Normally Closed Solenoids. Each solenoid controls the application of engine oil pressure to the intake and exhaust valve lifters on the cylinders selected to deactivate. Engine oil pressure is routed to the VLOM assembly from a passage on the rear of the cylinder block.
All 4 VLOM solenoids are connected in parallel to a fused ignition 1 voltage circuit, supplied by the powertrain relay. The ground or control circuit for each solenoid is connected to the engine control module (ECM).
When all enabling conditions are met for cylinder deactivation, the ECM will ground each solenoid control circuit in firing order sequence, allowing current to flow through the solenoid windings. With the coil windings energized, the solenoid valve opens, redirecting engine oil pressure through the VLOM into 8 separate vertical passages in the engine lifter valley. The 8 vertical passages, 2 per cylinder, are connected to the valve lifter bores of the cylinders to be deactivated. When vehicle-operating conditions require a return to V8 mode, the ECM will turn OFF the control circuit for the solenoids, allowing the solenoid valves to close. With the solenoid valves closed, engine oil pressure in the control ports is exhausted through the body of the solenoids into the engine block lifter valley. The housing of the VLOM incorporates several bleeds in the oil passages to purge any air trapped in the VLOM or engine block.
To control any contamination to the hydraulic circuits, a small replaceable oil screen is located in the VLOM oil inlet passage, below the oil pressure sensor. The oil pressure sensor is a 3-wire sensor which provides oil pressure information to the ECM.
During service, use extreme care in keeping the VLOM assembly free of any contamination or foreign material.
Engine Control Module (ECM)
The engine control module (ECM) is responsible for the management and control of all engine functions. Each ECM comes equipped with a specific set of software/calibrations designed for that engine and vehicle application. The ECM will determine engine operating parameters, based upon information from a network of switches, sensors, modules and communication with other controllers located throughout vehicle. Internal to the ECM is an integrated circuit device called a low-side driver. The low-side driver is designed to operate internally, like an electronic switch. An individual low-side driver controls each valve lifter oil manifold (VLOM) solenoid. When enabling conditions for V4 mode are met, the ECM will command the low-side driver to ground each VLOM solenoid control circuit, in firing order sequence. Internal to the low-side driver is a fault detection circuit, which monitors the solenoid control circuit for an incorrect voltage level. If an incorrect voltage level, such as an open, high resistance, or short to ground, is detected, the low-side driver, along with the fault detection circuit, will communicate the condition to the central processor in the ECM. The ECM will then command a return to V8 mode, set a corresponding DTC, and illuminate the malfunction indicator lamp (MIL) on the instrument panel.
Cylinder Deactivation Inhibit Reasons
Listed below are the powertrain conditions that will inhibit V4 mode, while operating under light load driving conditions:
? Engine manifold vacuum low
? Brake booster vacuum pressure low
? Accelerator pedal position rate of increase too high, electronic throttle control
? Accelerator pedal position too high, electronic throttle control
? Ignition voltage out of range
? Engine oil pressure out of range
? Engine oil temperature out of range
? Engine RPM out of range
? Transmission gear incorrect
? Transmission range incorrect
? Transmission gear shift in progress
? All cylinders activated via scan tool output control
? Minimum time in V8 mode not met
? Maximum V4 mode time exceeded
? Engine oil aeration present
? Decel fuel cutoff active
? Fuel shut-off timer active
? Minimum heater temp low, HVAC system
? Reduced engine power active, electronic throttle control
? Brake torque management active
? Axle torque limiting active
? Engine metal over temperature protection active
? Catalytic converter over temperature protection active
? Piston protection active, knock detected
? Hot coolant mode active
? Engine over speed protection active
? Fault Active or Fault Pending–cylinder deactivation is disabled for the following faults:
Brake Booster Vacuum Sensor
Manifold Absolute Pressure Sensor
Engine Oil Pressure Sensor
Engine Coolant Temperature Sensor
Vehicle Speed Sensor
Crankshaft Position Sensor
Engine Misfire Detected
Cylinder Deactivation Solenoid Driver Circuit
The scan tool output control is used to deactivate half of the engine cylinders, V4 mode, by commanding all of the solenoids ON, or deactivate one cylinder switching to a V7 mode, by commanding ON one solenoid. Listed below are the powertrain conditions that will inhibit V4 mode, or V7 mode, with the engine running, while using the scan tool output control function:
? Engine speed out of range
? Manifold absolute pressure (MAP) sensor fault
? Cylinder deactivation solenoid driver circuit fault
? Engine coolant temperature sensor fault
? Brake Booster Vacuum Pressure Sensor Fault
? Vehicle speed sensor fault
? Engine coolant temperature too high
? Engine not running
? Vehicle speed not zero
? Engine coolant temperature low
? Reduced Engine Power Active, electronic throttle control
Listed below are the powertrain conditions that will inhibit a cylinder deactivation solenoid from being energized, with the ignition ON and the engine OFF, while using the scan tool output control function:
? Engine speed not zero
? Transmission not in park or neutral
That’s a vaild point IMO. I too would be embarassed if my mighty Hemi sounded like Honda with a fart can on it half the time. I’m sure a custom ECU tune could disable the MDS.
Well, that sure sounds simple enough.
What could possibly go wrong in those sequences?
A clue is that GM is not too proud of this system. It is not even mentioned in the Owner’s manual. My first recognition of it was in seeing the display of instantaneous fuel economy, which had the words V4 mode or V8 mode. Fuel mileage was appropriately high, but we have to be concerned about the complicated apparatus necessary to make it work without damaging the engine.
The lengthy description that I find below is interesting, but scary!
